WadeB
- May 6, 2003
With BestBuy running a 24 month no financing offer beginning tomorrow thru Labor day for Reward Zone members, I’m likely to go pick up a TV tomorrow. The 2 sets I am considering are the new tabletop Toshiba 46h83 or the Mitsubishi Table top 42 inch set. I can’t remember the model number; it’s a BB exclusive model similar to the WT42311. Anyhow, I wanted to check with the trusted HTF crowd before taking the plunge. I’m leaning toward the Toshiba since it has DVI, is larger, and was the same price last I looked. It just has to fit into my Entertainment Center, and I think it will with some minor modifications (To the Entertainment Center that is.)
Anyone have strong feelings either way about either choice? Thanks!
