Help me with my settings for my new Denon receiver
Discussion in 'Archived Threads 2001-2004' started by darren_b, Feb 18, 2003.
  1. darren_b
    darren_b Extra
    Sep 13, 2002
    17
    Just bought a new Denon 1803
    BUt im still playing around with setting up the speakers, and have searched all the forums but still dont know what to do with the centre speaker.
    I have the Sub Woofer cross over at 80 hz.
    I have the following speakers-
    Front - Jamo X series 40 Hz-20000
    Centre- Jamo X5Cen 60HZ-20000
    Rear- Yamaha - 75 Hz-20000
    SUB - RP Acoustics - 35 HZ- 130
    Now my question.
    I have front to 'Large', rear set to 'Small'....Shall i set the Centre to 'Small' OR 'Large' as it only goes down to 60 Hz. Is it worth putting it to small and let the SUB handle bass under 80Hz for the centre?
    WHat would you set your speakers to in my case??
    Thanks for your help
  2. MartyK
    MartyK Agent
    Mar 19, 2001
    41
    darren_b,
    Set your center channel speaker to "small".
    Marty
  3. darren_b
    darren_b Extra
    Sep 13, 2002
    17
    Ill give it a go.....anyone else have any thoughts?? Should i set them all too small???????
  4. Henry_W
    Henry_W Stunt Coordinator
    May 7, 2002
    137
    In a much different set up (mainly high efficiency decent full range all around) I have set all speakers to small - If your sub is a good performer, it will be the best way to go, especially looking at your speaker specs..
  5. JamieS
    JamieS Stunt Coordinator
    Feb 17, 2003
    222
    Just my 2 cents. I have a 1603 same thing except 5.1 vs 6.1. I have Definative Tech DR7 in front (don't go as low as Jamos probably) and a C2 Center. I have my speakers all set to small. Setting to large seemed to overload the fronts on DVDs. Unless you have real boomer speakers or something lik a Def. Tech with a built in sub I'd set em to small.
