nddoublea77
- Dec 3, 2008
- Aaron
I currently own a dayton sub amp. I believe the hspa500 (500rms @ 4ohm). I bought it to drive a sub that I already had. I didn't do the proper research when building the box and here I am. The sub in the current set up is a 10 year old orion 15" dvc car sub. At the time it was their top of the line. It seems as though the amp doesn't have enough juice to push it. I don't have the T/S parameters and cant find them. I am not opposed to getting rid of the current box and sub and starting the project over properly, which is where you guys come in. The sub is in a dedicated home theater 11x16. The only limitation for box size is it has to be less than 2 ft wide as it sits in a recess in the wall. I like the way a 15 sounds but I am worried now that I don't have enough power. I have all the power tools needed to construct another enclosure. I don't want to spend a ton of money on a new driver but I want it to sound right. All it is used for is movies. Please help with your suggestions. Thanks a lot.
