Help me pick out best set-up for Athena's (1 Viewer)
RyanCai
Grip
Ok, i already have the following speakers
2 AS-F2's
2 AS-R1's
1 AS-C1
1 P-400 sub
i want the best setup possible for a 6.1/7.1
Another pair of AS-R1's best for my setup? What about AS-F1's for the rears will that work? Please suggest thanks.
RyanCai
Grip
What about buying another AS-f2 for the centers.
So the set up would be this
AS-F2's for the fronts & center
AS-R1's for the sides
AS-C1 for the rears, maybe buying another AS-C1 to make it 7.1?
Jack Gilvey
I'd go with all F2's across the front if possible...you have a projector? I went with an F1 at center since the F2 was a little too tall. The R1's work well as surrounds, although I mounted mine vertically as I found the sound too diffuse for MC music. The Athena bookshelf models would work well as surrounds although I needed something that could mount flush to the wall and the SB-1 and -2 are both rear-ported.When I had all F2's across the front, I used a pair of F1 as surrounds and they work extremely well although in my room they were much too close and distracting...so I went with the R1's high up on the wall.
I wouldn't bother with the AS-C1, or any other "dedicated" center, unless you really had to.
Yllanes
