Dave F
- May 15, 1999
Ok, here's the deal. I have a Tosh 5109 that is getting a bit long in the tooth, & I'm getting that itch to upgrade (Probably to a Panasonic RP56).
At the same time, I'm thinking of getting a secondary player - one that will play a zillion formats. I'd like something that has compatibility with VCD, SVCD, XSVCD, and can also play PAL discs on a HDTV. The Malata's look enticing, but since this is just a secondary player, I won't need anything that is really fantastic. Is there anything cheaper?
Dave
Dave
