Help me out with my confusuion.
Discussion in 'Playback Devices' started by Dave Hansen, Aug 7, 2005.
  1. Dave Hansen
    Dave Hansen Auditioning
    Aug 6, 2005
    4
    I have been kinda playing catch up with all the stuff going on with HD DVD players. If I understand correctly the connection is going to be either DVI or HDMI??
    I have a TV that accepts DVI inputs. Are there adapters or problems with hooking up a HDMI player into a DVI input on the TV. Thankss for helping out
  2. ChristopherDAC
    ChristopherDAC Producer
    Feb 18, 2004
    3,729
    HDMI-to-DVI convertors are available, which will allow you to send the video [but not the audio] from a HDMI source to a DVI display. Unfortunately, unless your display supports the HDCP data-control protocol, you will be locked out from viewing the picture.
  3. Dave Hansen
    Aug 6, 2005
    4
    Thanks for the info. I am not sure if my DVI input supports HDCP. I have a Sony KV-34HS510
  4. Dave Hansen
    Aug 6, 2005
    4
    Turns out that it is HDCP compliant, so I should be good to go I hope
