Christopher_R
- Dec 14, 2002
I thought I can decide on what to get for my mom and stepdads house but I need help. Budget I want to stay around 3,000-3,500 for everything. 200-300 dollars has to budgeted for cables and surge protector. Anyways though I have listen to what there is around here and I really think I have 2 systems set up. 70% HT and TV and 30% music
System one:
Athena SF-2 600 a pair
Athena AS-B2 230 a pair
Athena AS-C1 180
and for sub either a pw 2200 or a svs 20-35 pci or pc plus
System two:
Paradigm Monitor 7 620 as quoted
Paradigm CC-370 299
Paradigm ADP-370 670
and for a sub either a pw 2200 or a svs 20-35 pci or pc plus
Now here comes the hard part, the room is 31x19 and they are having 2 speakers built into the wall towards the back of the room, I am thinking about having maybe 2 lower priced paradigm in-walls speakers built in along with this house and make it a 7.1 system. The receivers I have considered are a yamaha rx 1300 if I don't do the 7.1 system or a 3300 if I do the 7.1 and harman kardon 7200 , but I am really leaning towards the yamaha because of some reliablitly problems and built quality with the harmon kardons and since I cant demo either system with the harman kardon only the yamahas. Anyways if I do go system 2 and a 7.1 setup do you think I could get sound towards the back of the room with the montior 7s because I really like the mid range on the monitor 7s compared to the 9s but I when I listened I thought the 9s covered more room. Also should I get the ADP-370s? They are expensive but I hear they envolpe you more in sound then the mini monitors would for rear sorrounds? Also with the yamaha 3300 will do I need to worry about the speakers. I know I probably wont turn them up that loud but with all the power I dont want to distort out the paradigm 7s that I why I am thinking about the 9s but the 7s I feel are a little better mid range and for HT. Last thing since the paradigms are not magneticly shielded will this matter. The salesman told me it wouldnt with my moms Sony HD rear projection tv? Anyways that was long but I dont want any other recommendations. I am leaning towards the paradigm system because I can deal and the warrenty and the fact that the place I buy the paradigms from will honor that warrenty. Thanks
System one:
Athena AS-C1 180
System two:
Paradigm CC-370 299
