Help me out here with a bridge for xbox(s)
Discussion in 'Archived Threads 2001-2004' started by JohnTKline, Mar 7, 2003.
  1. JohnTKline
    JohnTKline Stunt Coordinator
    Oct 6, 2002
    165
    Hey, how does that linksys wet11 work? I want to be able to hook up two xbox's up at the house for 1 on 1 play. I only have satellite connection right now so internet is out of the question for the time being. But I would like to hook up two xbox's wirelessly. One is close enough to the router where I could run cable from, but the other one needs to be wireless. I do have an extra 4 port hub in the closet if that may help for future connections.
    I guess I could run two wet11's for each box and run ad-hoc? But since I already have the linksys router/access point with a host and client pc, could I just get away with one bridge? How about if I had 3 x-box's??
  2. Brian Ruth
    Brian Ruth Supporting Actor
    Jun 21, 2002
    563
    John:
    Does the router you're using have wireless lan capability?
    If so, you'll only need one WET 11 bridge to connect both XBoxes.
    Otherwise, you'll need 2.
  3. JohnTKline
    Oct 6, 2002
    165
    Yes I have the Linksys BEFW11S4 ver.2 model wireless router.
  4. Romar Armas
    Romar Armas Second Unit
    Oct 17, 1999
    276
    We tried setting up a LAN game with 2 xbox's using 2 WET11's and it didn't work. However, if your only using 1 WET11 and the router, it should be no problem. Otherwise, you might have to read up on the 'Ad Hoc' mode feature.
  5. JohnTKline
    Oct 6, 2002
    165
    So did you use an ethernet cable for one and the wet11 for the other?
  6. Romar Armas
    Oct 17, 1999
    276
    No, we couldn't try this out, it was 2 WET11's. One on the main floor and one in the basement. The Main router was in the 3rd floor. And we couldn't get it working. I'm not sure if having one hooked onto the router via ethernet cable will make a difference.
  7. JohnTKline
    Oct 6, 2002
    165
    Did you try using the two wet11's in ad-hoc mode? I think maybe ad-hoc should only be used in very short distances. Maybe three different floors was too far away. And if you didn't disregard anything I just wrote!
    [​IMG]
  8. Romar Armas
    Oct 17, 1999
    276
    Unfortunately we didn't have time to play around with Ad-Hoc mode. I'm sure that would have remedied the problem. [​IMG]
