Help me organize my Bell'Oggetti a/v rack...
Discussion in 'AV Receivers' started by Henry Gale, Nov 18, 2005.
  1. Henry Gale
    Henry Gale Producer
    Jul 10, 1999
    4,628
    This is a separates topic so I picked this forum.
    My stepped style Bell'Oggetti came with 5 shelves, I bought a sixth. Yes, a small fortune.
    Just rearranged the furniture and am installing my new pre/pro and new 7 channel amp.
    There will also be an S-VHS deck, LD player, two DVD players and a turntable.
    Anyway, I was thinking it would make sense to put the pre/pro near the middle of things, hoping that would minimize cable runs. Then the amp over it? Under?
    Or on the top shelf with the handy griddle attachment? [​IMG]
    My TV sits next to this on an antique cabinet and I used to keep a couple of smallish amps in a closed (doored) shelf under it. This new monster amp probably won't fit in there and I want it to get more air than that anyway. Guess I'll start using that area to hold some box sets.
    So, any words of wisdom on stacking order?
  2. Eric Hargrove
    Eric Hargrove Stunt Coordinator
    Nov 24, 2001
    153
    Hi Henry,
    I would put the amp as low in the rack as you can and still be able to connect with the cables you currently have. The amp is most likely one of your heavier components and would be most stable down low. As for your other components, arrange them in a way that is most ergonomically friendly for you.
  3. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    True but heat rises basically warming everything else to boot.
    I keep my amp off to the side since there is only a on/off switch
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,184
    51
    9,110
    Katy, TX
    Wayne
    Yes, but there’s a shelf between it and the other equipment to shield them from the heat.
    Henry, IMO the best way to arrange your gear is to put the pieces you personally interact with – the phono, VCR and DVD player - where they’re easiest to access. I’d make the pieces you use the most the most accessible.
    Wayne A. Pflughaupt
  5. MikeNg
    MikeNg Second Unit
    Jan 22, 2004
    440
    All good advice here. Make it a) safe, b) user-friendly, c) workable with current interconnects. Hey, if you gotta buy more cables, you gotta buy more cables.
    I'd put the amp on the bottom.
  6. Henry Gale
    Henry Gale Producer
    Jul 10, 1999
    4,628
    Not really, these shelves are thorougly vented, full of holes, sievelike.
  7. Wayne A. Pflughaupt
    Aug 5, 1999
    6,184
    51
    9,110
    Katy, TX
    Wayne
    In that case I think I’d get a thick piece of glass cut for it – assuming you want the amp on the bottom, that is...
    Wayne A. Pflughaupt
