SteveSpoon
- Feb 12, 2002
Well, couldn't wait to build my own or purchase an expensive (more) sub, so for now, would like any suggestions on getting a little better sound out of it.
Let me back up. Went to ABC Warehouse and bought one of their Jensen JS1000-A subs for 84 bucks. It's my first sub, so was pretty pumped up on getting started with subwoofers. Twelve inch woofer with a 100 watt amp. Has a nice looking cabinet. Popped the woofer out (pretty light duty as expected) and noticed that it did have some insulation in it. Insulation was white in color, about one half inch thick on walls of sub.
Couple questions: Should I add more insulation? If so, what type do I add? Any other suggestions that may "tighten" up a sloppy, cheap sub?
Will end up messing with this sub for a while and then probably throw it on Ebay and move on. Thanks for any help.
Steve
Steve
