help me in choosing speakers....... (1 Viewer)
John Roger
I've seen that there r commonly two types of bookshelf 5 1/4 inch woofer and 6 1/2 inch woofer.Which one is best suited to use with my 8 inch sub?
Then what should I choose for center?
I have a 40W amp and a small entertainment room.Plz advice.
Drew_W
Whichever sounds better to you and fits into what you can afford. Specs like that are even less significant than wattage. Most speaker lines now have a matching centre, so once you find the stereo pair you like, finding the centre is a no-brainer.
You can mix and match of course, but 9 times out of 10, there's no need to.
shivamubtneha
