Help me finsih my setup (entry level)
Discussion in 'Speakers & Subwoofers' started by Pablo Abularach, Jul 22, 2003.
  1. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    Hi,
    I'm more than happy with my HT,
    Marantz SR6200
    Four JBL S26
    S center
    SVS 25-31PCi.
    But right now I'm looking to make a second setup for my computer, but I dont want to buy the logitech or altec lansing small speakers setups.
    Right now I dont want to spend more than $800 for the complete setup. So I already decided on two things
    Reciever: Pioneer VSX-912K
    Speakers: JBL NSP1 (II)
    But I'm still looking a sub, $200 or less, my options are
    Sony SA-WM500 $135
    Sony SA-WX700 $200
    JBL PB12 $212
    I wanted to go with the SA-WM40, but they are out of stock. And the replacement is the new SA-WM500, so I wanted to see if someone already had compare them to the SA-W40, or to see if the the price difference between the SA-WM500 and SA-WX700 is noticeble in sound and quality. Or maybe you guys think I should go with the PB12?
    Thanks for any replies,
    Pablo
  2. Ian-Fl
    Ian-Fl Second Unit
    Jul 13, 2003
    281
    I've been looking around for a sub as well and the polk psw202 is a possibility.
    I found a thread where it was compared side by side to a sony wm40 and the polk came out ahead.
    http://www.hometheaterforum.com/htfo...ghlight=psw202
    I found the psw202 at J&R for $199
