Help me find a 5-disc DVD Player with great AUDIO!
Discussion in 'Playback Devices' started by RichP, May 23, 2005.
  1. RichP
    RichP Second Unit
    Aug 26, 1998
    295
    Hello all,
    I just finished installing an-ceiling 5 channel speaker system (using Energy EAS-6C speakers) in my living room that will be used quite extensively for audio -- both 2-channel and multi-channel -- and I'd like to enlist your help in finding me a good 5-disc DVD player that will be used almost exclusively for audio.
    The 5 channels of amplification are installed as well as the volume controls... now all I need is a great source component!
    To that end, it should be able to play dts out, DVD-Audio and if possible be a nice solid 5-disc changer.
    SACD capability is not necessary since the primary CD player is a Sony XA777ES which handles that just fine.
    Also, I'd like to keep the price below $400 or so.
    Thanks in advance!!!
  2. Mike Keith
    Mike Keith Second Unit
    Jan 24, 2002
    324
    The Sony CX-777ES 400 disc DVD/SACD player would take care of everything, although it's about $500-600 on-line.
    Yamaha still makes a good 5-disc changer I think.
  3. RichP
    RichP Second Unit
    Aug 26, 1998
    295
    Thanks for the suggestion, but the Sony will not play DVD-Audio, which is a requirement for me.
  4. Dan Driscoll
    Dan Driscoll Supporting Actor
    Aug 1, 2000
    937
    2
    The Yamaha DVD-C750 (aka DV-C6770) has gotten very good reviews for its DVD-A/SACD performance. Ray Atkins at Audioholics raved about the 750's Redbook CD performance in his review.
    It's also a pretty decent video player and runs from $280 to $330, depending on where you buy it. The major downside seems to be a slow change from one disk to the next, on the order of 15-20 seconds.
