Steve Morgan
I have pre-ordered the Infocus 4805 and will putting the PJ on a table 11 feet from a screen that will drop down in front of the RPTV. Infocus says the throw ratio is 1.74-2.09. I do have about 6 inches wiggle room. What is my maximum screen size?
On another subject; Do to budget constraints I can not afford a micro perf screen so I will have to drop my 65 pound center channel to the floor in front of the rptv. Where can I get a CC stand that will angle for a reasonable price?
Steve
Steve
