Help me decide between these 2 receivers..
Discussion in 'Archived Threads 2001-2004' started by Vincent_S, Feb 6, 2003.
  1. Vincent_S
    Vincent_S Second Unit
    Nov 29, 2002
    450
    I believe I have narrowed it down to the Denon 2802 or Sony da2es. I listened to both and actually like the Sony ES better. They are both the same price btw and are the only ones I like that are in my price range right now.
  2. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
  3. Rich Wenzel
    Rich Wenzel Supporting Actor
    Aug 9, 2002
    556
    I don't understand your dilemna. If you think the Sony sounds better, why are you hesitating? Does the Denon do something that the Sony doesn't that you want? Otherwise, this seems like a no brainer.
    Rich
  4. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    I totally agree w/ Rich. The forum tends to be very pro-Denon, and maybe that's why you're hesitating. If the Sony sounds better, get it. That's all that matters, right? Unless, of course, the Denon will get your coffee ready and slice a banana up into your cereal for you in the morning.
  5. Vincent_S
    Nov 29, 2002
    450
    ^ LOL! I think you might be on to something there! I am going to listen to them again this weekend but I am leaning towards the Sony right now for the warranty.
