Help me clean my hands
Discussion in 'Archived Threads 2001-2004' started by Mark Dubbelboer, Jan 2, 2002.
  1. Mark Dubbelboer
    Mark Dubbelboer Screenwriter
    Oct 6, 1999
    1,008
    I work as a bartender when i'm not working as a student and whenever i'm done my shift three finger on my right hand are always bright red. I never really understood why, then one day realized it's from dunking my fingers into the maraschino cherries. There's really no alternative to using my fingers because it would take too long to get a spoon out and scoop, so my question is how do i get this crap off me?
    I wash my hands throughout the shift but it doesn't help, here it is two days after new years and my fingers are still red, especially the nails. I can't think of anyway to get this crap off me. any suggestions?
  2. Chris Derby
    Chris Derby Second Unit
    Oct 31, 2000
    371
    You're on your own as far as cleaning your fingers. But in the future, you might want to wear a latex or latex-alternative glove.
  3. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    On the nails themselves or behind them/underneath? You can always try nail polish remover on them I guess... Or perhaps some citrus degreaser that can be bought in automotive stores. Next time, make a marachino cherry dispenser, all you need is some clear food-grade PVC tubing about the diameter of the cherries you use with some kind of valve at the top for releasing them. Kind of like the old thumb on the end of the straw technique that uses a vacuum to hold liquid or in your case, marachino cherries. Then when you fill up an order that calls for M-cherries, just pop the vacuum enough for a cherry to fall. Can be used for olives and grapes too.. Oooohhh!
    And you can call it "Jay's Marachino Cherry Dispenser" ®2002
    [​IMG]
    Jay
  4. Ryan Wright
    Ryan Wright Screenwriter
    Jul 30, 2000
    1,875
    Go into an automotive store and get yourself some Orange stuff. I don't remember exactly what it's called - quick orange, fast orange, super orange. Something like that. I've got a huge jug of it at home I use for cleaning my hands after working on my car. That stuff is amazing. If it won't clean your hands, nothing will.
  5. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    I think Ryan is talking about Fast Orange, I have it, it works pretty good on bike/car grease and stuff. Smells good too, almost too good. I think the best soap I've ever tried though was Borax powder soap, feels exactly like small rocks but it was awesome and probably took a layer of your skin off afterwards!! [​IMG]
    Jay
  6. Darren Davis
    Darren Davis Stunt Coordinator
    Oct 9, 2001
    248
    I think the Orange stuff is Gojo or something. It works pretty well because it has small grains of sand in it to act abbrasively.
  7. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Can you make a good tequila sunrise, Mark? I love a good tequila sunrise.
  8. Eric Kahn
    Eric Kahn Guest
    You are going to have to live with stained fingers, the red coloring they use makes a good stain, and has been absorbed by your skin, it has to grow out
    you could try some of the "miricle stain remover" they show on TV, but most soap and detergent products are not going to do anything
    even though it takes time, start using a spoon or one of the bar toothpicks
  9. Mark Dubbelboer
    Oct 6, 1999
    1,008
    Tequila sunrise coming right up Jack.
    Jay I think your "Jay's Marachino Cherry Dispenser" might be a bit out of my league...I didn't last too long in engineering:p
    I forgot all about that fast orange stuff. for the longest time i never knew why i associated oranges with my grandfather till like three years ago i noticed he used fast orange as a hand soap, and hence always smelt citrusey. I worked tonight and i just kept like 5 cherries in the jar w/out liquid, then i just kept filling it when i needed to. that might work on a wednesday but come this weekend i think i'd be struggling to keep up. I'll have to go pick up some fast orange.
    i remember as a child working on our family farm anytime i got really dirty, usually paint, they'd spray gasoline on me and that stuff worked wonders. sure it's prolly unsanitary, and i'm kinda surprised i can still see, but damn if it didn't work
    thanks for the suggestions guys
  10. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    can you make a decent long island? [​IMG]
    noting beats a good LIT [​IMG]
  11. SteveGon
    SteveGon Executive Producer
    Dec 11, 2000
    12,251
    Out, damned spot! [​IMG]
  12. JohnRice
    JohnRice Lead Actor
    Jun 20, 2000
    8,850
    230
    The Fast Orange was my first thought. It probably won't get it all out, but should help. You might also try Goo Gone. This is not exactly what it is designed for, but might work. Going on the stain theory, you might follow up the Fast Orange with a short soak in diluted bleach. About 1/2 oz. in a quart of water should do it. Then you probably should wash your hands with Fast Orange again to get the bleach out.
  13. Jon_Are
    Jon_Are Cinematographer
    Jun 25, 2001
    2,036
  14. Steve Berger
    Steve Berger Supporting Actor
    Sep 8, 2001
    972
    3
    I use Comet cleanser on my hands to remove tough dirt and stains. It's a little harsh but contains bleach which might do the trick. WD40 works for greasy dirt and glue residues but not much help on stains.
