Chris Carswell
- Mar 5, 2002
Hey Guys,
Because of YOU fellow posters, I finally decided to do it and got myself a PE amp and Tempest. I was originally going with a 300 L box tuned to 19.5 HZ but it was a little big for my room. I have been told that if I keep it ~ 210L (7.25 cu ft) I should be OK. So I will. I am going with a Chris Tsutsui type Frustum Pyramid design. I will finish it in High Gloss Piano Black (P.I.T.A. but well worth it).
Brian already helped me out a lot but I had a few more ???
1. Adire's site said to have it at 7cu ft tuned to 20hz with 2 4" ports 16.5" long. When I run Win ISD I come up with 1 4" port at 9" or 2 4" ports at 21" Which do I go with?
2. Brian said to use some Dacron Batting on the inside but I can't get any. Should I line it with insulation or polly fill & if so how much?
Any other tips I should be aware of, please LMK. I plan to put it up on the web like what Pat does but it won't be that well documented. Thanks again.
Chris
Chris
