Bill W.
- Apr 9, 1999
Here's what I looking at. I was about to order an SVS sub when I started reading about the Tumult.
So I have decided to either:
1. Build my own Tumult based sub, or:
2. Order an SVS 16, (one of the versions) I haven't decided which.
The sub will go in a fairly large living room, approx. 20x15 with 9 foot ceilings, which has 2 large 6 foot wide openings into the entry way and dining room. The entryway has an 18-25 foot vaulted ceiling.
I would like it to go at least to 16 Hz, size is not an issue, as it will fit nicely behind my existing towers.
All help and comments will be appreciated.
Bill
Bill
