Help me adjusting my projector
Discussion in 'Home Theater Projects' started by vnthierry, Jun 12, 2019.
Tags:
  1. vnthierry
    vnthierry Auditioning
    Jun 12, 2019
    vnthierry
    I am mounting Optoma WU515ST to a ceiling and currently I am getting this shape. Please help me how do I adjust my projector so that the shape becomes square rectangle? Please see my attached image.
    The white grid lines is the current showing. I like it to be like the red rectangle
    [​IMG]
  2. JohnRice
    JohnRice Executive Producer
    Jun 20, 2000
    10,765
    1,135
    9,110
    A Mile High
    The projector is at an angle to the wall. It needs to be centered on where the image is being projected and aimed straight at it.
  3. greggor
    greggor Second Unit
    Jan 6, 1999
    409
    18
    110
    Greg
    What John said. Squaring up the projector with the wall is probably the most important thing to get right when mounting and adjusting your projector. Everything else can be dialed in using the projectors adjustments and the mount adjustments.
  4. xx Brian xx
    xx Brian xx Stunt Coordinator
    Dec 18, 2017
    120
    35
    10
    Brian
    First, if possible, square it better to the wall, then look for the projectors "keystone: settings and adjust as necessary.
    If you are too far off center, the keystone won't be able to completely square up the image.
    Brian
