HELP: looking for technical info. on SONY VPL HS10
Discussion in 'Archived Threads 2001-2004' started by DidierN, Feb 1, 2003.
  1. DidierN
    DidierN Auditioning
    Jan 31, 2003
    2
    Hi everyone !
    I plan to buy a front projector (Sony VPL HS10 or Yamaha LPX 500) in a few months,
    but before that I would like to have my HT room completely
    finished (sound treatment, lighting...).
    So here is my problem :I would like to build and mount a
    custom made 16:9 screen BEFORE owning my projector,
    and I need precise data for screen size, distance and height setup.
    I found this kind of information for the Yamaha on
    http://www.yamaha.com/yec/products/video/LPX500.htm
    (full end-user manual and ceiling mount setup manual are
    available for download there), but I cannot get the same
    for the Sony :
    - does someone know where I can find the Sony VPL-HS10 user manual
    and PSS 610 ceiling mount manual for download ?
    - is the HS10 setup the same of the Sony VPL-VW12HT
    (I got this one on the net so I could use the same data)?
    Thanks for the help
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    The throw data is not the same as the Sony 12HT (nor the 10HT and 11HT) which are all short throw whereas the HS10 is long throw. The following may be of some help to you... HS10 throw chart - XLS
  3. DidierN
    DidierN Auditioning
    Jan 31, 2003
    2
    [​IMG] Thanks a lot for this great URL.
    With this calculator I'll be able to setup my screen
    so keystone correction will be minimal.
    Thanks again.
    :-D idier
