HELP! Infornation overload- can't narrow it down
Discussion in 'Archived Threads 2001-2004' started by Randy Noel, Jun 21, 2002.
  1. Randy Noel
    Randy Noel Stunt Coordinator
    Mar 28, 2002
    101
    Here's my deal - I have a Toshiba 65HX81, and JBL Studio Series speakers (S26 rears, S36 Fronts, SCenter) Strictly 5.1 setup, 90-95% TV/Movies. I'm looking for a good quality receiver, and I want to stay under $300.00, because I would be in big trouble if my lovely wife knew what I had already spent (she just doesn't understand![​IMG]). I have been looking at Pioneer 811S, H/K AVR120, and even a SHERWOOD NEWCASTLE R-956. Give me some direction please. My HT is about 15W x 18D x 7.5H.
    (message heading should read "information," not infornation"):b
  2. Randy Noel
    Mar 28, 2002
    101
    I'm certainly open to other models, and could possibly go a bit higher[​IMG] . Help me out here, people!
  3. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    I don't follow prices too much but have been very impressed with Harman Kardon 320. good power and features for a pretty good price.
    I would think with a TV that nice you'd want a pretty decent receiver.
    Check out crutchfield.com for specs and features. What do you want from a receiver? Great sound or tons of features?
  4. Randy Noel
    Mar 28, 2002
    101
    All I will be hooking up to this are Prog. Scan DVD, Possibly a separate CD Player, VCR, and Cable (Probably the new Toshiba STB/Direct TV Receiver down the road.) We don't listen at extremely high volume. My main interest is good quality HT sound.
  5. ThomasL
    ThomasL Supporting Actor
    Mar 13, 2001
    963
    Randy,
    do a search through the forum for "budget receiver" over the past 2-3 months. For your price range (~$400), the Pioneer VSX-D811S is a very good value. I have one and it performs very well for HT use which is what you'll mainly be using your receiver for. It's also a 6.1 receiver and has pre-outs enabling you to go down either upgrade path (rear speakers or separate amplification). The search should reveal a number of threads that are pertinent to you.
    How many sets of component inputs does your set have? I would hook up the progressive scan dvd player directly to the tv irregardless of whatever receiver I bought. It just eliminates another connection and another set of cables.
    Other receivers in the $400 price range are:
    Yamaha HTR-5540/5560
    Marantz SR4200/SR5200
    Onkyo SR500/SR600
    Denon 1802
    good luck,
    --tom
