Help in transferring files
Discussion in 'Computers' started by Brian Perry, Dec 29, 2003.
  1. Brian Perry
    Brian Perry Cinematographer
    May 6, 1999
    2,807
    I just bought a Sony PC110 DV camcorder and have just started to learn the process of converting the tapes to DVD. I was successful in capturing the video from my first tape to my laptop using Pinnacle Systems software. The reason I used my laptop is because it has a firewire port, whereas my desktop does not. Unfortunately, however, my DVD burner is on the desktop, so I now need to move the large AVI files from the laptop to the desktop.
    The first possible option I'd like to explore is using the LAN I have set up. Right now I have a cable modem going into a Dell router that feeds my desktop (via ethernet port) and laptop (via a wireless card). Can I share files between the two computers with this current setup? If so, how? And if not, would I need to get a USB cable to connect the computers for file sharing?
    Thanks!
  2. Jeff Blair
    Jeff Blair Second Unit
    Apr 30, 2000
    335
    There is a kit that allows you to hook up 2 PC's via a USB port. But it will be slow, about 1.1meg. If you can see your desktop PC from your laptop you should be ok. Make a directory on your desktop, and share just that one. That way just incase you have someone trying to look in on your network, they just see that one. The Dell router should be ok. And, you should get speeds close to 8+ Mps.
  3. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,766
    489
    9,110
    Or... how about installing a Firewire card in your desktop PC to do the capturing from your DV camcorder? The firewire card is pretty cheap (around $35 for a firewire/USB2.0 combo card). I recently bought a Koutech model PFU331 combo card which worked pretty well for my purposes in retrofitting an older PC without firewire.
  4. Brian Perry
    May 6, 1999
    2,807
    Jeff/Patrick,
    I actually took both of your advice--I was able to figure out how to "see" each computer on the network (though transferring huge files takes forever, so it's not a viable solution for video), and I ended up buying a Belkin Firewire card for $40 at Best Buy.
    Thanks!
