Help in selecting receiver.
Discussion in 'AV Receivers' started by Alan Wise, Feb 20, 2004.
  1. Alan Wise
    Alan Wise Stunt Coordinator
    Jan 28, 2004
    236
    Please help me.
    I am in the midst of upgrading from a HTIB that I bought over two years ago (Pioneer HT-510).
    I am in need of a decent receiver to replace the CD/DVD/Receiver all in one unit that came with the HTIB.
    Here is what I have done in the past three weeks:
    Sony KP57WS510 HD ready RPTV (and Comcast HD via 5100 box).
    Replaced limp axx passive HTIB sub with a new ARPR1212 active 250 amp unit.
    New Sony 725 progressive scan DVD player.
    Plans for this next month:
    New (or used) A/V receiver (see my ideas below)
    New (or used) speakers (2 front, two rear, one center).
    My room is 15' X 15' with a nine foot ceiling, and wood paneling on the walls. The carpet is a very low cut "Berber(?) style".
    My receiver ideas thus far (based upon budget of $ 300.00 or less):
    Refurbed H/K AVR125
    New or Refurbed Panasonic SA-HE100
    Pioneer VSX-811
    Denon AVR-1604
    Onkyo TX-SR501
    JVC 8030
    Yamaha RX-V540
    As you can see I am looking at a rather long list of contenders. I know better that to look to Sony for lower end sound equipment (I obviously lie their video stuff)
    What I want from a receiver is:
    -Clean, clear sound to fill my room almost soley for movies (DVD, or cable)
    -DTS capability as well as Dolby Digital.
    -Subwoofer pre-out.
    -additional pre-outs for other amp?
    I like the H/K125 but I am concerned with the low power rating.
    My intentions would be to potentially upgrade again in two to three years (ah yes the upgrade bug).
    I look forward to using the experience and advice of this forum to help me decide.
    Best Regards, Al. Wise
  2. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    I pm'd you. Out of those receivers you might want to consider ones with pre-outs as then your next upgrade could be adding a 2/3/5 channel amp into the mix. That is what I did with my Pioneer 811. I know the HK/Onkyo don't have pre-outs on those models not sure on the rest you listed but my guess would be probably not.
  3. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    Don't be. It's real-world power will be comparable to, or will exceed, everything else on the list.
  4. Alan Wise
    Jan 28, 2004
    236
    Chad,
    I looked and did not find a PM from you.
    Thanks, Al. Wise
  5. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Maybe I sent you an email then....
  6. Alan Wise
    Jan 28, 2004
    236
    Chad,
    I do not find an e-mail either.
    However, I did study your home theatre system.
    I like your choice of AR's for speakers.
    I am leaning towrds AR myself.
    Any advice or opinions regarding your current set up would be greatly appreciated.
    Thanks, Al. Wise
  7. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Now check your PM....
  8. Alan Wise
    Jan 28, 2004
    236
    Chad,
    Got your PM.
    Thanks, Al. Wise
