rodney wiley
- Nov 23, 2001
Well the Denon AVR-1082 is FRIED:frowning: Is there any other unit I should look at in the 1500.00 range? Or should I pocket the difference and get a new 3802/1082
hey rodney, what happened to it?I believe Rodney indicated that a lightning strike created a power surge which took out his receiver.
Being a Denon lover myself, I'd recommend sticking with the 1082/3802. If you have a few extra $$, you could even attach a separate power amp. The 3802 is supposed to be $699 delivered from 6th Ave. I've also found the 1082 for $651 delivered from NXGEN.Com. Let us know what you decide on.
Between the 1082/3802 and the DA5ES, Denons are much better receiversI think this is an opinion not a fact.
I think this is an opinion not a fact.Of course it is.
Having heard the 3ES and the 3802, I would choose the 3802. Very simple. Don't worry since I saw that you ordered a 5ES, and you will not be disappointed. Both are good, but I preferred the 3802 to the ES for a number of reasons. I also preferred the sound of Marantz SR6200/7200 for music to the 3802, which is why that is what is in my system...
