Richard Moya
- Apr 9, 2002
I purchased my AVIA disk about 9-11 months ago. Ive used it MAYBE a dozen times or so. Maximum 18 times. The inner ring is CRACKING!. Right where it goes onto the little holder in the jacket. It looks like its holding on for dear life but is ready to any minute. I think the inner ring is encoded with some info and I would hate for it to quit working because its cracked. Im sure you all know this is an expensive DVD. Any ideas if they will step up to the plate and replace this? Should I be concerned? Anyone else suffering with the same thing? I was really pissed seeing this with such little use.
Thanks in advance
Thanks in advance
