HELP! I need a new remote!
Discussion in 'Archived Threads 2001-2004' started by NathanP, Oct 31, 2001.
  1. NathanP
    NathanP Supporting Actor
    Aug 13, 2001
    841
    My secondary system (music only) is equipped with a vintage 1986 Kenwood KVR-A70R and it's remote has worked flawlessly since then.
    Thing is, the remote is busted and I can't find any info on it or the codes.
    Is there any CHEAP universal remote that'll remedy my situation?
    How would I go about programming my system to do this?
    Nathan
  2. NathanP
    Aug 13, 2001
    841
    Is anyone gonna help me?
  3. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    It might help if you state what product the Kenwood is. Is it a reciever, tape deck or what?
  4. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Brett Andrew DiMichele
    You may or may not be able to get a cheap universal OFA
    remote that can control the item. If it's realy old chances
    are there won't be a code in a new remote's code base. The
    other alternative is to buy a Universal Learning Remote if
    your old Kenwood remote works at all, and use the old remote
    to teach the new one. Of course if you old remote is totaly
    DOA then you are outta luck...
    Check out http://www.remotecentral.com
    Brett DiMichele
    My Home Theater Site!
    [email protected]
  5. NathanP
    Aug 13, 2001
    841
    The Kenwood is a reciever and the remote is totally dead.
    Any help is great.
  6. John A. Casler
    John A. Casler Second Unit
    Apr 29, 1999
    475
    Go to www.remotecentral.com and post the same question.
    If they don't have the codes or a remote to use, it can't be done.
    Good Luck
    John A. Casler
  7. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Try the Cinema 6 or 7 from One for all. These run pretty cheap (under $30) at places like wall mart and radio shack. there's an extensive extended code base for these litle wonders available at http://www.starbase314.com/RemoteCodes.htm
    http://www.mts.net/~glendap/
  8. Sean Conklin
    Sean Conklin Screenwriter
    Oct 30, 2000
    1,720
    Nathan,
    Replacing a Kenwood remote with a universal remote can be a challenge, I don't know about your particular Kenwood, but I have tried to find a code for my newer Kenwood and none of the universal or the Digital Cable remotes will work.
    Sean
    "I was thinking of the immortal words of Socrates who said.......I drank what?"
  9. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    Nathan & Sean: I agree that the One-For-All Cinema 7+ IQ series is the remote to look for. You can usually find it at Sears for $24 or so. The C7 is very customizable and users have even found a way to use a PC with it for programming and code backups.
    (There was only one key for my Kenwood receiver that the C7 didn't know. And if you have the PC interface, there is probably a way around that too.)
    Go to http://www.hifi-remote.com/ofa/index.shtml for some great info.
  10. NathanP
    Aug 13, 2001
    841
    Alright, I may try for this cinema remote as I could use an all-in-one remote.
    You guys think it'll work on my situation?
    What remotes would you guys recommend under $50?
    Nathan
  11. Thomas_A
    Thomas_A Second Unit
    Feb 2, 2001
    398
    Have you ever thought about contacting kenwood? just a question
