Jeff
- Jun 30, 1997
Ok, I did a bad thing. I got a new Epson 1650 Photo Scanner and I noticed some very faint "stains" on the rear of the glass. I went to clean it with a soft cloth and a tiny bit of windex but that didn't work, so I figuered it must be on the other side. Anyway, I took the cover off, which was extremely easy, much more than expected, and I cleaned the other side, making sure it was dry before putting back on.
So now I get a white band coming down all my scans. Does this mean dirt has fallen on the lens, or whatever? I know nothing about the mechanics of scanners so where should I be looking to get rid of this dirt? I already sprayed with a can of compressed air and that didn't help. It was worse yesterday, though, I had three bands and two were a different color. If I can't clean it without taking anything apart, excpet the cover, I won't bother. I'll just take it back and play dumb. And I won't feel bad either since the "stains", which so far don't seem to affect scans, can not be whipped clean.
You can see a scan here:
http://members.shaw.ca/majestyk/epson.jpg
Jeff
Jeff
