I may have a problem....at least DirecTV thinks so.
I wanted to add an additional TV to my satellite
service. The TV is located in a separate room.
I went out and bought a basic DirecTV receiver.
I only have ONE cable coming into the house.
Therefor......
I am running ONE line off a 3 LNB satellite
and simply splitting it to two televisions with
separate receivers...
DirecTV says this is not good. Can someone
explain why?
Someone suggested I use an A/B switch instead.
What do I need to buy from Radio Shack?
A simple A/B switch? I take it with this switch
setup I will not be able to have both TVs running
at the same time?
Therefor......
explain why?
at the same time?
