Help! how to display 720p on Mits 65819?
Discussion in 'Displays' started by Manuel, Feb 16, 2004.
  1. Manuel
    Manuel Stunt Coordinator
    Jun 29, 1999
    199
    Here is the deal. I play my X-Box on the big screen (I know it is not good for it but oh well). A lot of the sport games do 720p and my Mits 65819 cannot display it. I do have a Dish 6000 receiver that will read 720p and upconvert to 1080i(don't know if that will make a difference but oh well). Is there anything I can get or a setting that I am missing where I can get the set to display 720p upconverted?
  2. DuWayne
    DuWayne Stunt Coordinator
    Sep 8, 2003
    160
    If I am understanding correctlly...You want o play ESPN NBA 2004 (or such) in 720p mode, but your componet inputs don't support 720p (just 480p and 1080i).
    Unless you buy some external box that will allow you to convert 720p to 1080i (that will sit inbetween your xbox and Mit.)....The answer is NO. To tell you the truth, I don't think you would like what you saw after the conversion.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Be patient, I'll bet products will start to surface that will do the scale'n for you and the newest products will probably do a very high level scale too.
    I watched Jurassic Park III last night from ABC, and as I understand it, they broadcast 720p, so my OTA Tuner must of been scaling it to 1080i, and the results seemed as good as any other 1080i content I have viewed. So I know quality scaling is possible.
  4. Rajeev_s
    Rajeev_s Stunt Coordinator
    Dec 20, 2002
    184
    I dont think setting the X-box to 480p instead of 720p will look all that bad compared to 720p. You should be ok. Not many CRT RPTVs can display 720p native. They all convert it to 1080i even if they accept it.
  5. dan fritzen
    dan fritzen Second Unit
    Mar 19, 2001
    304
    I would call it a big difference, usually the 720p gets rid of a lot of jaggies, ie antialiasing.
  6. DuWayne
    Sep 8, 2003
    160
    I agree, 720p Games look a lot better. A LOT
