Help: How do I command/control the PC ???
Discussion in 'Computers' started by Edgler Vess, Aug 26, 2004.
  1. Edgler Vess
    Edgler Vess Extra
    May 22, 2003
    24
    Hello,
    I need your help and I´m a total newbie in this area:
    The situation is the following.
    I have the PC and the projector in different rooms but contiguous.
    Through a hole I manage to pass the necessary cables to the connections.
    The problem is this:
    1)
    How can I command/control at the distance the computer, particularly in gaming situations?
    2)
    Are there any Gamepads with cables of three meters or should I buy a normal one and do some alteration putting a longer cable ?
    3)
    What about wireless controllers?
    Do they work fine with a wall between ???
    Thanks in advance
    Edgler
  2. Paul Stanley
    Paul Stanley Stunt Coordinator
    May 1, 2004
    98
    IR maybe?
  3. Francois Caron
    Francois Caron Cinematographer
    Jul 31, 1997
    2,156
    11
    610
    Ottawa, Ontario, Canada
    François Caron
    I created two USB to RJ-45 adapters using a pair of female RJ-45 boxes and a couple of three foot USB extension cables. I then connected a forty foot long network cable between the two, threw in a USB keyboard and mouse to the package and I was done!
    No weird drivers, no IR delays, no batteries needed! [​IMG]
  4. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Bluetooth devices can supposedly work up to 32 feet. A Logitech MX900 + keyboard is an option. I like the USB extension idea, it's what I did but with a regular USB cable to a hub.
