Help hooking up single HE-15 to Crown K2 Amp!
Discussion in 'Archived Threads 2001-2004' started by Tim Christianson, May 17, 2001.
  1. Tim Christianson
    Sep 30, 1998
    17
    I am almost finished with my HE15 sub and will be hooking the driver up soon. How should I wire the beast? (details please)!
    Do I just hook up each voice coil to each amp channel? (That's 8 ohms, correct?)
    Is this the most efficient way?
    I know amps put out more power when they see a 2 ohm load, but how do you wire it? Should I go this route, or just leave it at one channel per voice coil?
    Tim
  2. Julian Data
    Julian Data Second Unit
    Oct 5, 1999
    408
    Hmm. You have a K2.. Nice KICK ASS AMP! [​IMG]
    Parallel the VC.. 2 Ohms..
    1250/ch with K2.. or bridge it.. 2500W
    Be sure your house is strong enough! [​IMG]
  3. Chris Hoppe
    Chris Hoppe Stunt Coordinator
    Sep 5, 2000
    53
    Yep, parallel the VC's... (+ to + and - to -) Bridge the amp and run one set of wires to it.
    Yes, that is bridging into a 2 ohm load, and yes that is like a 1 ohm load per channel, but I have used mine in that very configuration and the amp has no problem with it!
    Bridged into 4 ohms, the K2 puts out 2500W. I expect there will be a little more juice left in the power supply, so bridging into 2 ohms is probably something like 3000W!
    Just be careful... you can bottom the driver with that amp! If it's too powerful, you can run one channel to each VC. That'll cut the power quite a bit, but it may be all you need.
    You're using a subsonic filter aren't you? That's pretty essential with that much juice!
  4. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    The HE15's have 2-3ohm VC's, at least mine do [​IMG]
    If you parallel them the amp's looking at approx 1.5 ohm load. Now it will drive this; but a kinder gentler way is one VC/channel, unless you really need all the available power
  5. Tim Christianson
    Sep 30, 1998
    17
    Thanks guys. I am hooking her up
    now.
    Tim
  6. Steve Hanna
    Steve Hanna Agent
    Aug 4, 2000
    25
    Hmmm...
    Bridging even the mighty K2 into 1.5 ohms isn't really a good idea. Just because you've gotten away with it so far, doesn't mean you won't pay the price later on. Abused equipment won't last as long as well cared for equipment.
    One channel into each coil will be the equivilent of bridging into 6 ohms. ~2kw total. What's that HE15 VC rated for again?
    Steve Hanna
    Audioaficionado
  7. Julian Data
    Oct 5, 1999
    408
    1kW/VC total 2KW
  8. Steve Hanna
    Steve Hanna Agent
    Aug 4, 2000
    25
    I rest my case.
    Steve Hanna
    Audioaficionado
