Chris White
- Feb 12, 1999
We're trying to paint our Toshiba tv black and having major problems with a large plastic piece. As you can see in this picture, the left speaker grille has been removed. The piece I'm referring to is in the middle below the screen.
We first tried to use spray paint, but it was streaky so we used a Kilz (oil based) primer. After the primer, we again tried Krylon Spray Paint (enamel?), which is supposed to be "ideal for plastic."
Either this spray paint doesn't work well on plastic or we just got a bad batch because it spits and bubbles and streaks and just isn't a smooth finish.
Next, we tried a very light sanding followed by a coat of poly urethane. That didn't help either. We're now waiting for the poly urethane to dry so we can sand it off.
At this point, we're thinking we need to either try another brand of spray paint or perhaps an oil-based paint.
Any suggestions?
http://www.bus.ucf.edu/cwhite/theater/theater.htm
Any suggestions?
