Help!!-getting a split screen with new toshiba hd-a3 (1 Viewer)
lorrod
Rod Schafer
I am setting up a new HD-A3 player and it is displaying a split screen....the right picture on the left and the left on the right. I have a Zenith IQB64W10W, which accepts 1080i input, but does only have component inputs, no HDMI. Does anyone now what to do here??
troy evans
Double check to make sure the correct color component cable is in the correct input. Also, make sure the inputs are in securely. Sometimes when the component cables screw on tips get loose it can cause interference, so make sure they are screwed tight as well. If that does in fact apply to your cables.
Cees Alons
Cees Alons
Rod,
Welcome to the forum!
What Troy says, and also check if your HD-A3 is really set to 1080i (not -p), because you say your Zenith can only handle that.
You didn't tell us if you get that split screen (actually, it's shifted half a horizontal line to the right or left) on HD material only, or on SDVD, or both.
Cees
tgroskop
