Seungsoo Hwang
- Aug 6, 1999
Heh it seems I cut my endcaps for my sonosub a tab bit small, so they slip in and out easily. Is there any way to go about fixing this? Anyone else make such a mistake and got around it somehow? Or should I just nail it to the side and goop a bunch of silicone in the seams? ARG what a mistake, I could have easily avoided by checking the first circle to make sure, but no, I had to cut em all out, cut the driver and the port holes along with it. Any suggestions? *there is about a 1/8" gap at the widest..*
thanks!
thanks!
