Help finding a car adapter for a Panasonic LV-75 portable dvd player?...
Discussion in 'Playback Devices' started by todd s, Mar 6, 2004.
  1. todd s
    todd s Lead Actor
    Jul 8, 1999
    7,133
    76
    9,110
    I am going on a long trip and need a power adapter to plug into a cigarette lighter plug for my Panasonic LV-75 portable dvd player. Does anyone know one that will work and is not to expensive.
    Thanka!
  2. todd s
    todd s Lead Actor
    Jul 8, 1999
    7,133
    76
    9,110
    Anyone??
  3. Scott Barnhart
    Scott Barnhart Stunt Coordinator
    Jan 3, 2001
    202
    If you can't find what you need, you can always buy a power inverter, which plugs into the cigarette lighter on one end, and has a normal 110 AC plugin on the other. That is what I got for my portable DVD player, since I figured it would be useful for other things too.
  4. Ralph B
    Ralph B Supporting Actor
    Apr 27, 2003
    584
    I just bought a car adapter on ebay for $6.00 shipped for this same reason. it outputs 1.5 to 12v and does the 9v that I need for my player. dont pay radio shacks $20 price. ebay has tons of them. the guy I bought from has alot!
  5. todd s
    todd s Lead Actor
    Jul 8, 1999
    7,133
    76
    9,110
    I am completely dumb on this subject. Can anyone tell me what I need? Here are the specs:
    input ac 100-240v 50/60hz 30w
    output dc 9v 2a
    Thanks!
  6. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    As mentioned above ... you need an inverter. Costs under $30 and can be had at a walmart or target store.
    Plug inverter into cig lighter ... plug DVD player power supply into inverter ... or plug toaster into inverter ... it's that easy.
    Regards
  7. Ralph B
    Apr 27, 2003
    584
    you can use a cig lighter adapter which is much cheaper. 2000MaH with 2.0A output will work for you. they are switchable from 1.5-12v and are protected from overload and heat. they come with alot of adapters to fit your unit. seen one at walmart for $14.99 which is a good buy!!!!!!!!!
