Help figuing out what sub to buy
Discussion in 'Speakers & Subwoofers' started by rogerssa, Feb 15, 2005.
  1. rogerssa
    rogerssa Auditioning
    Aug 24, 2002
    10
    I need to purchase a sub for my HT. The room is 19 x 12 open on one side. I'm using JBL Northridge speakers for the 7.1 surround.
    I'm looking to spend under $250 if possible, but I could go a little higher. Right now I'm using a old Dual 10" Cerwin Vega center/sub combo. It pretty bad. Only goes down to 38hrz or so.
    I'd like a sub that can get in the low 20's.
    Recomendations?
  2. David Bikeman
    David Bikeman Stunt Coordinator
    Aug 15, 2004
    164
  3. rogerssa
    Aug 24, 2002
    10
    Looking at the Dayton. Seems like an amazing sub. Looking at them on Parts express. I see the sub. How do you get a full setup for $150? Or is that link you are talking about just the SUB then I build a box and power it with a amp of some sort?
  4. KenLeBlanc
    KenLeBlanc Stunt Coordinator
    Jan 31, 2005
    117
    JBL E250 is $249 delivered at J&R. I ordered one. Hopefully it doesn't disappoint.
  5. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
  6. rogerssa
    Aug 24, 2002
    10
    Two of these should be awesome then. [​IMG] One in the front of the room one in the back. as long as I can keep them from canceling one another.
  7. MikeyWeitz
    Feb 10, 2002
    939
    Pick up a BFD off of ebay for
