Help! Dead Barco Data 600
Discussion in 'Archived Threads 2001-2004' started by al chaney, Jun 30, 2002.
  1. al chaney
    al chaney Extra
    Jul 31, 2000
    23
    [​IMG] I need help with a dead projector. the unit will not power up , no lights, nothing. Any help apprceiated.
    al
  2. arbey
    arbey Auditioning
    May 20, 2002
    Try to see if all fuses are OK, they are located on the second board on your right standing behind the unit ground setup. Change the N/Sboard, the one on the left. Check if the power supply is set on the right voltage. Do you have the little magic box, the controll switcher that used to be plugged in the back?
    hope this helps a bit...
  3. derek
    derek Second Unit
    Dec 20, 1998
    494
    There are quite a few BD600 experts on avsforum.com CRT forum. [​IMG]
