LindaSilka
- Jun 12, 2003
Hello,
I found this site by luck, and have no sleep from last night checking out the whole layout, wow this site is big. My problem follows:
I have the Sony KP-61HS30 TV, on the back it has a place where I would think, the connection from the PC will be going. It has a S-Video, then under that has a Video and L/R Audio connections.
The Vaio is a 2.5GHz P4, 512MB PC-2100 DDR, 64MB Nvidia
GeForce4 MK 440. On the back has a S-video (out) and in the front has a S-video with video and L/R Audio (input).
I'm not a wiz when it comes to this, but I do know somethings. I thought I would hook up a S-video cable from the (out) on the PC and connect it to the back of TV. When I switched the TV to Video 1, nothing shows. I do not know what I'm doing wrong, or if I have the correct setup, cables, or whatnot. Please if anyone coujld just lend a hand or two, it would be of great help. I'm trying to get the kids to do some work on the TV, and Hubby is not to PC friendly...thanks a bunch
Linda Silka
Linda Silka
