Help Choosing TV
Discussion in 'Archived Threads 2001-2004' started by James Morrison, Sep 12, 2002.
  1. James Morrison
    Jun 24, 2002
    47
    I have around 2K US to spend on a tv.
    I don't really know that much about them.
    The room is 17-1/2x22.
    Anyone have a sugestion?
  2. Juan_R
    Juan_R Supporting Actor
    Sep 4, 2001
    683
    We are going to need more info before we can help you.
    Are you looking for a CRT base TV? Or a rear projction (RPTV) TV? Do you want a flat screen? What will you be using the TV for? HD, DVD, cable, DTV? Does the room where the set is going to go have a lot of windows?
    I think after you answer some of these questions we might be able to help you.
  3. James Morrison
    Jun 24, 2002
    47
    Well like I said I don't know that much about them
    I will be watching DVD's and Digital Cable.
    I guess an rear projection HDTV? w/ a 16:9 aspet ratio.
    what's my options?
  4. Shane Archer
    Shane Archer Agent
    Dec 10, 1999
    28
    I'm partial to the Panasonic 53WX42, for the price. I couldn't find another TV that I liked that still fell under $2K. They are on dealer floors for between $1700-1800 right now (maybe less if you find the right dealer), and with a little (maybe a lot) of tweaking they look great.
    If you want to go smaller (or bigger) they make the same TV in 47" and 56" varieties.
