DougWright
- Mar 24, 2000
I have recently upgraded to a Yamaha RX-V1400 and I am now starting to rethink my speaker settings. This unit comes with YPAO which is a automatic speaker configuration tool and it seems to do a good job of setting my speakers up, but I find my sub a little over powered now, stuff rattles in the room that id not use to .
So I want to set it manually.
My Mains are Paradigm Monitor 7's and the sub is a Paradigm PDR 10.
The Monitor 7's have the following ratings, Low Frequency Extension of 33 Hz (DIN). Which says indicates -3dB in a typical room. Frequency Response is +/- 2 dB from 47 Hz to 20 kHz.
The PDR 10 has Low Frequency Extension of 27 Hz (DIN) and cutoff frequency is from 50 Hz to 150 Hz.
If someone tell me what to set it to and could explain briefly why, I would sure appreciate it.
Also should I set the Monitors to large or small in the setup?
