Help choosing DVD changer
Discussion in 'Playback Devices' started by KennyD, Jan 7, 2005.
  1. KennyD
    KennyD Extra
    Dec 2, 2004
    15
    I have a Pioneer VSX 1014TX Receiver in the mail on the way here, and now I am trying to choose a DVD changer to go with it.
    I don't care about SACD, and my receiver decodes Dolby Digital and DTS, so that doesn't matter either.
    I am big into music, and I will probably use the DVD changer for 60% music, 40% DVD's.
    Things important to me:
    5-7 disc changer
    optical and coax digital outputs
    s-video and composite video outputs
    zoom
    dvd-r and mp3 playback capabilities
    progressive scan
    good cd playing features, since I will play a lot of cds, (mostly mp3's) with it.
    I am looking to spend about $100 after shipping, but possibly up to $150.
    Does anyone have a DVD changer that sounds like it would be good, or any recommendation?
    I am all for a last year's model, or something like that in order to get good features and save money.
  2. Max F
    Max F Second Unit
    Jun 26, 2004
    250
  3. KennyD
    KennyD Extra
    Dec 2, 2004
    15
    I remember looking at that one, and I think there was something that it didn't have that I wanted. I think it may have been that it didn't have optical digital output, and that it only had the coax digi output. I prefer to have both digital outputs so that any other source can take whatever it needs, and I can still hook up the DVD changer.
    One that I came across that seems to have everything is the Sony DVP-NC875V. Does anyone have any experience with this one, or know of any pros/cons with it.
    I haven't yet decided upon it, I am still just looking at everything I come across.
  4. Marvin Richardson
    Marvin Richardson Supporting Actor
    Jul 16, 1999
    750
    I wasn't crazy about it because it was so painfully slow switching discs and also starting discs. The picture quality was okay, as was the sound quality. I took it back and spent twice as much and got the Yamaha DV-C6770 (same as DVD-C750). Its a five disc changer that plays DVD-Audio and SACD, but since you don't care about that I don't know that you'd be interested.
  5. KennyD
    KennyD Extra
    Dec 2, 2004
    15
    Here's a different one, the Toshiba SD-6915. It is cheap, and it looks like it has all that I want. Does anyone have any pros/cons with this one, or know anything about it?
  6. Grant B
    Grant B Producer
    Mar 29, 2000
    3,210
    I have 2 cd changers and 2 DVD changers. The DVD changers are great for movies but to slow for cds like was said earlier.
    You can pick up 865 & 875s pretty cheap nowdays.
    Then if you like it pick up a cd changer later.
    I find they are great for getting rid of stacks of discs without boxes and keeps them pristine.
