Will Cunningham
- Feb 21, 1999
Howdy,
I am going to be getting a 3k budget to pick out an HDTV sometime soon and I was wondering what you guys suggest. I have a 60" mitsubishi TV right now and am pretty happy with it. I am getting the 3k via a promotion at work.
I am not sure what I plan to do with the TV, I don't expect that I will be able to get a large enough HDTV to replace my 60" 4:3 set. That leaves me with a bit of a decision, I did think about trying to use the TV as a huge monitor for my computer...but that seems like a waste.
I have been out of the loop on HDTV's...I was planning on saving for a front screen projector some time in the future so I have not been tracking things. Does anyone have any suggestions? What kind of HDTV do you think 3k could buy, would upping he ante to 4K make a huge difference?
Any info would be appreciated!
Thanks!
Will
Thanks!
Will
