Help - Can't get my Yamaha C900 to Work
Discussion in 'Archived Threads 2001-2004' started by BenP, Mar 2, 2002.
  1. BenP
    BenP Auditioning
    Aug 18, 1999
    7
    It's working with CDs, however when I insert a DVD some will play, but others won't. The player doesn't recognize the discs and says "no disc." Any thoughts on what might be wrong.
  2. Selden Ball
    Selden Ball Second Unit
    Mar 1, 2001
    412
    Selden
    Ben,
    Focusing for DVDs is much more critical than for CDs. The tracks are much narrower and closer together. It may be that your player is having some internal mechanical problems with the lens focusing. You might try using a CD cleaning disc in case it's just a dust problem, but you may have to consider having the player cleaned and adjusted by a repair shop.
    Sorry.
