Help calibrating speakers with 2 subs.
Discussion in 'Archived Threads 2001-2004' started by Steve Morgan, Apr 7, 2002.
  1. Steve Morgan
    Steve Morgan Second Unit
    Nov 10, 1999
    328
    Farm in Kansas
    Steve
    I am using the internal test tones on the Lex MC-1. I turn 1 sub off and calibrate to 75db's to all other speakers then turn it off and turn other sub on and calibrate to 75db's with spl meter.When I turn both on the SPL meter reads 81db's.Should I calibrate each sub to 69db's so when I turn both on it reads 75db's or what? Thanks!
    Steve M.
  2. Steve Morgan
    Nov 10, 1999
    328
    Farm in Kansas
    Steve
    Come on Audio gurus help me out! Is everyone so worried about SVS subs they can't respond to a simple calibration question[​IMG]
    Steve
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,100
    33
    Katy, TX
    Wayne
    Steve,
    Since both subs run at the same time when you use your system, calibrate with both of them on. Simple!
    Of course, you have to make sure the two sub's levels are matched to each other as well...
    Wayne A. Pflughaupt
