Eric Martello
Grip
- Oct 13, 2003
This might be a fun project for some of you to get involved in. Also a good way to get info on the latest gear. HTPC Forums is building a project HTPC, but they're reviewing each component they use in addition to the finished HTPC itself. Plus, I think they'll be giving it away after the reviews are done. Check it out here.
