Help - Black ring/halo around golf ball ???
Discussion in 'Displays' started by AndyPJR, Apr 5, 2004.
  1. AndyPJR
    AndyPJR Auditioning
    Aug 26, 2002
    6
    Watching golf yesterday on NBC HD. In most shots showing someone putting, or the ball on the green, the ball had a perfect black outline. I have a Hit 50v500 LCD RPTV; HD from the cable Co. (Adelphia in Ct via their Scientfic Atlanta cable box) Cable box set to 1080i.
    This is the first time watching golf in HD. I don't think it happens on the regular stations. However as I'm writing this I forgot to check the regular station to see if it was there also.
    Tried playing with contrast and it didn't help.
    What is this ?
    Any way to correct it ?
    Oh yeah, happened to the soccer ball while watching soccer also.
  2. Brent Hutto
    Brent Hutto Supporting Actor
    Aug 30, 2001
    532
    I suspect that you were actually seeing an upconverted standard-definition picture. To my knowledge, that tournament on NBC was not being covered with HD cameras. Probably you were seeing some sort of edge-enhancement type ringing around the golf ball.
  3. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Sounds like ringing from EE. Make sure your sharpness is set correctly, or turned down, this may also add to the ringing problem. Look for high-contrast transitions between bright and dark colors, especially horizontal and vertical edges, look up close, and look for ringing.
    Here is an excellent page if you don't know what I'm talking about: http://www.videophile.info/Guide_EE/Page_01.htm
  4. Steve Berger
    Steve Berger Supporting Actor
    Sep 8, 2001
    973
    3
    110
    The ring appeared to be there on standard analog (53" RPTV) also . Maybe they were using a variation on the hockey puck enhancement to make the ball more visible -- or they offshored video processing.
  5. Mike Wladyka
    Mike Wladyka Supporting Actor
    Jul 24, 2003
    630
    i agree with chris, about the sharpness being off...have you calibrated your TV with avia?
  6. AndyPJR
    AndyPJR Auditioning
    Aug 26, 2002
    6
    Thanks for the info guys !!!!!
    I have not done any kind of calibration.
    Sorry, Newbie here !
    I was hoping it wasn't a characteristic of LCD RPTV technology. THX !!!!
    The avia is a calibration DVD correct ?
    Where do i get this ?
  7. ChrisWiggles
    Aug 19, 2002
    4,791
    Avia or digital video essentials are the main two discs to use, I do not have DVE, so I cannot comment, but Avia is complete for most advanced users, and has good beginner explanations. The key is to listen to the whole explanation and understand why things happen, as people tend to get confused and not understand that some of the things described ONLY happen on CRT devices, and then look for them in digital displays.
    You can get each directly, I beleive, and they can be found most places, and tons of places online.
