ok I just finish building my new computer and I'm having trouble with the BIOS...first off, this is what i bought:
-lian li PC-69 case with antec true power 550w power supply
-Asus P4C800 deluxe motherboard
-2GB of dual ddr400 memory
-intel p42.6ghz cpu at 800mhz bus
-160GB seagate barracuda serial ATA hdd @ 7200rpm
-ati raedon 9800 pro video card
-pioneer slot load dvd-rom
-samsung 955DF 19" monitor @ 0.20mm dot pitch
now my problem is in the bios settings, i go through and set everything up. Yet everytime the power is cut from the unit the bios resets itself, it gives a CMOS settings error, CMOS clock not set and I gotta go through and redo all the settings. I checked the jumper on the mb, and its fine, i even put on a new jumper just incase. The only thing I can think of is that the battery is faulty on the board. but I bought this thing brand new, so i dunno how the battery could be dead. Are there any other reasons for this error to be comming up??
