Help! Bi-wiring
Discussion in 'Archived Threads 2001-2004' started by Jack, Dec 15, 2002.
  1. Jack
    Jack Agent
    Feb 5, 1999
    35
    Hi,
    Been over a year since I set up my speakers etc.. I have a yamaha 2050 and am trying to bi wire my speakers Paradigm monitor 7's. From what I remember I have 4 wires 2 positive and 2 negative per speaker, I put the positives and negatives together at the receiver, than I split them at the speakers right?? Some reason neither speaker working when I did that lol.
    So what I forget?
  2. Shannon W
    Shannon W Stunt Coordinator
    Oct 11, 2002
    199
    Don't forget to take the bridge out thats on the terminals on the speakers before you Bi-Wire!!!!
    Shannon
  3. Jack
    Jack Agent
    Feb 5, 1999
    35
    Yes they are out, still not sure why the speakers are not working humm
  4. TerryHenson
    TerryHenson Agent
    Jul 10, 2002
    32
    The bridge makes no difference if you're just trying to get sound. You should have two wires, one from each of positive terminals on your speaker going to the + side of corresponding channel on your amp. Likewise for the negative side. Repeat as necessary.
    Frankly, when you get done, you most likely will hear no difference anyway.
