Help: B&W 805 vs. CDM 9NT
Discussion in 'Speakers' started by Bob Snelgrove, Feb 17, 2004.
  1. Bob Snelgrove
    Bob Snelgrove Auditioning
    May 10, 2003
    10
    Hi Guys,
    I have a chance to buy either in used mint condition for the same price. I have heard both but not side by side. The 9nt's on paper look like the clear winner, but a very experienced audiophile told me the 805's were clearly in a different (better) leauge. I have to decide pretty quick, so help [​IMG]
    thx
    bob
  2. Mike Butny
    Mike Butny Stunt Coordinator
    Mar 3, 2002
    66
    Due yourself a huge favor and buy the 805's. They are awesome.
  3. Bob-N
    Bob-N Supporting Actor
    Jul 26, 2001
    915
    Got a good sub? Go 805's, no brainer. If no sub, then buy a good sub and go 805's. The 9NTs are nice and have pretty good low end if you don't have or can't afford a good sub.
    Bob
  4. Daniel Mai
    Daniel Mai Stunt Coordinator
    Oct 2, 2001
    225
    And what would be considered a "good" sub for the 805?
  5. JoeyTadeja
    JoeyTadeja Agent
    Mar 3, 2003
    30
    The Rel Q or Rel ST series of subs would work best. Of course you can always get the ones that B&W sells. However if you are on a budget you can get the Sunfire Super Jr. on Ebay for less than $700, however, they are not as musical. Rel sells the Q108E model for $750.
    www.rel.net
  6. Bob Snelgrove
    May 10, 2003
    10
    Thanks, guys
    I'm just curious how the 2 way, non FST-Midrange equipped 805 could outperform the 9NT, not even worrying about the bottom end performance? I had thought the FST from the higher end Nautilus speakers clearly gave the 9's the edge. I'm assuming they share the same tweeter, also?
    Not arguing, just looking for answers [​IMG]
    thx
    bob
  7. WilliamJulien
    Nov 23, 2001
    22
    Bob,
    I listened to the 703's, HTM7, HTM1, 804's, and 705's. I was going to buy 2 703's, HTM7, and 2 705's. I did not like the sound (as much) of the 705's and HTM7. The midrange sounded muddier to me, which I attribute to the lack of FST. The midrange is by far the most important element to a speaker system and the is NO substitute for the FST to me. I ended up with 4 804's and a HTM1. Of course I can not comment on the 9NT.
  8. Bob Snelgrove
    May 10, 2003
    10
    Thanks, Guys
    It seems the 9NT's are *very* close to the 804's and that's why I thought they should outperform the 805's!
    thx
    bob
  9. Gary D. Gray
    Gary D. Gray Auditioning
    Dec 13, 2003
    5
    I am in a similar situation (ie, 805 vs. CDM 9NT) and found this thread in a search, so I thought I'd revive it.
    Wouldn't the CDM 9NT be more closely related to the 703 than it is to the 804? My impression is that the CDM 7NT is similar to the 704 and the 800 line is better than them all.
    I will be using the speakers for primarily home theater purposes (about 90%), and am leaning toward purchasing the 805's with stands.
