Tim_B
- Jan 25, 2001
Ok, I posted a couple of days ago on recommendations for my speakers, I just wanted to consolidate the various options that I am now considering.
I just placed an order for a Denon 1803! And now I need a 5.1 speaker setup. My budget is $500 to $750. The room is 12x12 (8' ceiling) with Saltilo Tile floors (large area rug). With the room limitations, I expect that a very nice set of speakers may be considered overkill.
I will be using the system for 75%HT and 25% music. I was thinking about throwing down $500 for the Acoustic Research HC6's (or Dahlquist 5.1 system) after reading the love letter review in Perfect Vision. Then I could work on getting a better HT setup in a year or so. However, I am getting the urge to spend a bit more and not have to worry about upgrading in a year or so. Here is what I am considering right now. Let me know what you think and what else you would suggest.
AR HC6's
Dahlquist 5.1
Energy Take 5.2
Ascend Acoustic 5.1 system (with or without the HSU VTF-2)
Axiom Epic Master (or Epic Mini w/ M2i's as fronts)
JBL System (S36II, S-Center II, S26II surrounds) and whatever sub.
Athena Point 5 system
Atlantic Technology System T70
NHT (4 nht superones, Super Center, Supersub)
Ok, that about does it.
Tim
AR HC6's
Dahlquist 5.1
Energy Take 5.2
Tim
